Looking for Boonton 9242 Instrument Driver
I am looking for an instrument driver for a Boonton 9242 RF Voltmeter. Any help appreciated!
Message 1 of 9
(4,614 Views)
Accepted by tylerH
Is that instrument SCPI compliant? If so you don't necessarily need drivers for that exact model.
SCPI defines standardized interfaces for several kinds of instruments -- including voltmeters.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 9
(4,608 Views)
Accepted by tylerH
I do not see a specific driver for the device but, the device is SCPI compliant and a few hours of work starting from a Instrument Driver Project Template would get one ready to go.
[Edit] Adding to Mike's post... RF Voltmeters are not well defined in "Compliant Capabilities" but, go ahead and start with an RF Power Meter template... There are a lot of DMM functions that are NOT available to that device
(Mike, Really? ......)
The meter really is simplistic in its "MEASurment:XXX" functions and would be a great way to learn how to write an Instrument Driver for a SCPI Compliant device..... I'd pass it to any intern for a learning experience!  (And yes, I'll answer questions from them)
Message 3 of 9
(4,601 Views)
Thanks Mike and Jeff, trying to help our programmer out with a done solution. Was hoping someone had a driver they knew of.
Message 4 of 9
(4,597 Views)
In case no one has one - http://www.ni.com/tutorial/9097/en/
Message 5 of 9
(4,579 Views)
Thanks Mike, trying to help our programmer out with a done solution. Was hoping someone had a driver they knew of.
Message 6 of 9
(4,576 Views)
Accepted by tylerH
See the edit to my last post... Instrument Driver Templates would make that fairly easy
Message 7 of 9
(4,563 Views)
OK, thank you Jeff and all, this is my first post and I am impressed with the rapid replies, I just had a discussion with our guy, I think he will be able to handle it!
TylerH
Message 8 of 9
(4,557 Views)
TylerH
Keep posting.... We like the easy onesSmiley Very Happy
Message 9 of 9
(4,546 Views)
