Can I use PID toolkit in 64 bit LabVIEW?
I switched to a new PC and installed 64 bit LabVIEW, hoping more memory would help caching and streaming large images continuously acquired by my cameras. But I just realized that the PID toolkit I have been using doesn't support 64 bit LabVIEW.
I tried the method provided in this post (https://decibel.ni.com/content/docs/DOC-22604), which, as I understand, is basically copying all the vi's and related files from 32 bit LabVIEW to 64 bit LabVIEW folders and then mass compiling them. I was able to copy all the files except that I didn't find any file in resource\Framework\Providers\ that sounds related to PID and Fuzzy Logic. Unfortunately, the compiling of a number of PID vi's failed. If I try to call them in my code, the vi is shown as nonexecutable.
Is there a way that I can get the PID vi's to work in 64 bit LabVIEW?
Thanks!
YJ
(4,633 Views)
YJ,
Unfortunately, PID depends on a DLL that in 2013 and earlier is only compiled in 32-bit.
However, if you open the PID.vi in the Array instance, you can add the 64-bit option to the diagram disable and then, use the G-version of the algorithm instead of 32-bit.
Let me know if you need more information...
Barp - Control, Simulation, RTT and HIL - National Instruments
(4,586 Views)
CAN YOU PLEASE EXPLAIN IT WELL
(3,352 Views)
It was a long time ago. I ended up open the PID vi in my code and recompiled it in 64 bit LabVIEW.
(3,345 Views)
