Can I use a LabVIEW Realtime DLL also in CVI?
I have a LabVIEW Realtime DLL for a Göpel-Card.
Can I also use the DLL with CVI?
Best Regards
Heiko Mayer
(3,745 Views)
Is this for a Boundary Scan board (JTAG)?
We were calling the API (dll) from Labwindows-CVI.  You should also be able to use the Labview-RT dll with CVI.
You can also launch your VIs from CVI through ActiveX automation. See the example program under cvi\samples\activex\labview.
Most posts talk about the reverse action... C/C++ dll being called from Labview-RT.
Hope this helps,
RayR
(3,746 Views)
You may also have a look at this thread..
(3,740 Views)
            thank you very much for your quick answer
          No, this is a PXI-CAN Card.
         If I use the RT-Labview DLL with CVI, I get following Error: Fatal Run-Time Error The program has caused a 'General Protection' fault at 0000:03AFA2AF.
         Do you have an idea, which at the code could be wrong? I do not find the error.
         Best regards
         Heiko Mayer
(3,709 Views)
Sorry, that was the wrong source-code
Here is the actual code...
Best regards
Heiko Mayer
(3,704 Views)
