Can I use a numeric control to change the shown index of an array?
Hey folks,
This might be one of those questions getting the "why would you wanna do that?!" reactions, but I'm wondering if there's a fairly simple solution I just dont know about...
I know arrays aren't exactly gems when it comes to UI applications, but with my particular application if I could get a numeric control to be used to set which index of the array is shown, that would be awesome.  Also, assuming thats possible then I'm thinking I could figure out how to have two booleans that would increment/decrement the shown element while updating the numeric too...
Any ideas?
Any input much appreciated!
thx
(2,801 Views)
Accepted by plyons.gks
Is this you wanted to achieve
(2,792 Views)
YES.   precisely what I was looking for. Kudos to you!!!
I had tried something similar but missed the build array...
much thx!!
-pat
(2,787 Views)
I'm curious.  why not just show the index display.  it even has increment and decrement arrows?
(2,784 Views)
I want to have the numeric and booleans trigger event struc frames... there probably a bunch of ways to pull this off though...
thx
-pat
(2,781 Views)
I exactly thought about the same thing Jeff.. But it was like a Rubed code so I enjoyed doing it. 🙂
(2,780 Views)
