Can I use active directory to validate users?
I figured it out myself. I simple followed the instructions given by "dkentner".
Message 11 of 19
(4,147 Views)
I know this thread is pretty old, but here is an easy way to validate active directory user's credentials (username and password combination). This VI is .NET System.DirectoryServices.AccountManagement (3.5.0.0)
Actually I found the information as PowerShell script here. It should run on Windows 2000 and later.
Message 12 of 19
(4,056 Views)
I am trying to retrieve the windows local user groups that the current windows user is a member of using the  EXP-AD-4003-Testad-010.vi and UsersGroups.vi provided under this thread.
When I type my username and password I am receiving the error 1172 as seen in the attachment on the `directory searcher find one` invoke node.
Could anyone tell me how the syntax should be like to stop receiving the error on the probed wire in the attached jpg?
Thanks in advance.
Message 13 of 19
(3,959 Views)
sezergin,
The syntax I am using matches your... for example mine is (sAMAccountName=dkentn). I did notice that I'll get the error you are seeing if I am disconnected from the network or ther is no Windows Server (active directory) on the network.
Dennis
Message 14 of 19
(3,896 Views)
I can also reproduce the exact same error when the network is disconnected or the user-ID is an empty string. I guess sezergin is trying to get access to the users and groups defined on the local Windows machine, not to Active Directory users and groups.
This is something I like to know also 🙂 If someone has already VI for it, please share it with us.
Nick
Message 15 of 19
(3,877 Views)
I know that this thread is old, but you can also use the ActiveDS Type Library to authenticate users.
Message 16 of 19
(3,749 Views)
I would bet that OpenDSObject returns an object refnum in the variant. Not closing that as well will result in a memory leak until the application is shutdown. No problem if you only validate once every so often but a total no go for an application that would stay active all the time and validate users repeatedly.
Rolf Kalbermatter  My Blog
Message 17 of 19
(3,729 Views)
Your probably right. I hadn't considered that for this example. I haven't used the Active DS library in quite some time, and I am sure you can expose other groups, users, computers, etc.
Message 18 of 19
(3,722 Views)
This post was awesome. Just what I needed to authenticate a windows user!
Message 19 of 19
(3,488 Views)
