Can I use the count tick for measure a duration of a process?
Hi all
I intend to use the different of two count tick for measuring the duration of the process as shown in my code. But so far, I struck with two problems.
1. I cannot initialize the count tick function.
2. I cannot get the result from that code.
Can anyone help me in this, please?
Noppadon
Message Edited by Noppadon on 05-14-2005 04:01 AM
Message 1 of 8
(4,084 Views)
Just move the initial tick count out of the loop !
CC
Chilly Charly    (aka CC)
Message 2 of 8
(4,078 Views)
Hi Chilly
Many thanks, and as you say, it works after I remove the initial tick count outsind the whil loop, but that time is not like I expect. Because I need to get the execution duration in the sequence loop.
thanks,
Noppadon
Message 3 of 8
(4,074 Views)
That's different...
If you want to time the duration of a process, you ahve to add a frame in the sequence, before reading the ticks. leave the iniatial tick count inside.
See the attachment
CC
Message 4 of 8
(4,069 Views)
Hi
That is sound great, but I cannot open the attachment, because I still uses version 7, so could you please save in Version 7 ?
thanks,
Noppadon
Message 5 of 8
(4,063 Views)
Here it is...
Message 6 of 8
(4,061 Views)
For easy code readability, I would suggest a 3-frame flat sequence to isolate the timing process from all the rest of the code that could occur in a typical loop. (Otherwise you're also never quite sure if the start timing really occurs immediately before the process to be timed.)
Message 7 of 8
(4,053 Views)
Thank you very much in this.
Noppadon
Message 8 of 8
(4,034 Views)
