Can I use transparency in custom Tree Symbols?
I have a graphic image that I edited (in MS Photo Editor), selected a Transparent Color for the background and saved it as a PNG file. I want to use this as a custom tree symbol.
However, the Tree control seems to ignore the transparency selection and uses a white background. Without transparency, the tree "selection" color looks goofy when used with the custom symbol.
Is there a trick to this?
(3,274 Views)
Check out the example program: Traversing Tree Controls and Setting Custom Controls and the subVI "Create Mask by Alpha.vi" in particular.
There's some transparency settings that you can set for images.
(3,274 Views)
Thank you. The "mask" was the missing puzzle piece. I don't think I would have guessed that.
On a related note: I notice that when I set a custom icon into a tree that the image undergoes some changes in appearance. Sometimes a thin black outline appears and it just doesn't look as nice as the original image. Viewing the "picture" in LabView, prior to setting the tree, shows a fine image. But after the image is shrunk to fit into the Tree it is not as good.
Is there a reference to what operations are applied to the image prior to it showing up in the Tree?
(3,274 Views)
Hi Mike,
The only documentation for image rendering is in the Help for the VIs themselves. PNG files have been known to display a little funny sometimes on tree controls and you may want to consider reading in JPEGs or Bitmap files instead.
Hope this helps.
(3,274 Views)
