Can IEEE 488.2 Labview software/drivers used on a IEEE 488.1 instrument
for example
"STPT" {Set Total Pressure)} Commanded total pressure (hPa):
"STPT 888.25" set 888.25 hPa.
Return: “STPT 888.25” if the command has been correctly entered
“E” if value is out of limits
"STPT?" to read commanded value
Return: “STPT 1235.55” if 1235.55 is hPa commanded value.
"STPT" {Set Total Pressure)} Commanded total pressure (hPa):"STPT 888.25" set 888.25 hPa.Return: “STPT 888.25” if the command has been correctly entered“E” if value is out of limits"STPT?" to read commanded valueReturn: “STPT 1235.55” if 1235.55 is hPa commanded value.
u mean to say "STPT 888.25CR"  or "STPT 888.25LF" ?
Message 11 of 11
(510 Views)
