How to monitoring LED status in main VI, while LED changes in sub VI?
In a sub VI a LED is switched on and 5 sec later the LED is switched off. How can I read the LED status in the main VI? The sub VI gives me only the end situation (LED off)
(2,877 Views)
Hi Johnny45,
you can register a user event for this control in your main vi. Another option is to send a notification if the control value changes. The main vi should be able to react on this notification.
Mike
(2,861 Views)
 This'll work, too, if you don't mind polling.  It fits your stated question to "read the LED status".
Jim
(2,843 Views)
Accepted by topic author Johnny45
Hi Johnny45,
please see attached the examples for my suggestions.
First Example: sub_LV85.vi and main_LV85.vi
Second Example: Example2_sub_LV85.vi and Example2_main_LV85.vi
Hope it helps.
Mike
(2,817 Views)
Mike,
Thank you!
I expected the problem was easier to solve.
Johnny
(2,786 Views)
