hi, im trying to do the event count using USB 6009..
im using an toggle switch as an input to PFI0,i have configured the DAQ with edge, falling parameters..whenever i give toggle the switch,there is no increment in the count value..anybody help me out in this regard..
(2,884 Views)
Can you post your code?
Ed
Edward Motts
Certified LabVIEW Associate Developer
(2,866 Views)
And can you post a schematic of how you've wired the switch?
Ed
Edward Motts
(2,865 Views)
i have attached my code
(2,842 Views)
You forgot the schematic.
(2,837 Views)
Accepted by topic author Sumithra_Nagappan
There is also a quick way to test this with out using a switch, connect one of the DI/O lines to the counter input. Then toggle the line. This is just  a sanity check but it is a classic "demo" of the counter input in several tutorials I have seen. But yes the switch diagram would be needed to see what is going on.
Alan
(2,826 Views)
