Can LabVIEW querry MAX for active devices?
Is there a  way for LabVIEW to query MAX for active devices?
If at some point a measurement instrument (a DMM for example) is added to my test system, I would like to be able to obtain the IO device name from MAX and then be able to communicate with that device without having to manually interact with MAX.
Thanks in advance.
(3,646 Views)
Hi AT,
you can check active devices.
Are we talking about DAQmx or VISA?
(3,644 Views)
Currently, I'm interrested in a VISA (USB) device.
(3,636 Views)
Accepted by AT1
Hi AT,
then you are interested in using the VISAFindResources function?
(3,621 Views)
That's what I was looking for.  Thanks so much for your help!
(3,542 Views)
