Can LabVIEW "read" Microsoft Windows Environment Variables?
@billko wrote:
I have to think it hasn't changed from "this_parameter=this_value".
Oh sorry let me be clear.  My software development skills 14 years ago were much less then they are today.  The code probably works, it just isn't a development style I think someone should try to replicate.
Message 31 of 53
(1,562 Views)
Oh, okay.  Yes I try not to look at code I generated a decade ago.  But sometimes it's useful to see your humble beginnings to see how far you've come.  But maybe best that it be a private viewing.  😄
Bill
CLD
(Mid-Level minion.)
Message 32 of 53
(1,557 Views)
@David_Grucza wrote:
Since I asked this question NI has added palette VIs for working wit Environment Variables.
What toolkit installs this palette? I do not see it in LV2020 installation.
Message 33 of 53
(1,197 Views)
My theory is that David meant that some of these things are in the NI palettes. But you cannot access ALL of them without the.NET method that I posted. Perhaps I am wrong, I did a search just now and didn’t find anything either.
Message 34 of 53
(1,107 Views)
I just looked up all the list of variables on the MS website, dumped them into an enum and called the system exec.
Bill
CLD
(Mid-Level minion.)
Message 35 of 53
(1,092 Views)
I find it more convenient to use the Windows API.
Message 36 of 53
(1,086 Views)
Your solution is elegant; it was much simpler to program using system exec.
Bill
CLD
(Mid-Level minion.)
Message 37 of 53
(1,028 Views)
Many thanks.
Message 38 of 53
(995 Views)
Convinience is a matter of taste. 😁 I also prefer the Windows API path over .Net or command line tools.
.Net because of the additional overhead of interfacing between the LabVIEW managed environment and the siginificantly different .Net managed environment.
Command Line has the overhead of instantiating a separate process each time and while the cost for that under Linux is considerable, it is factors worse under Windows.
The Windows API is in process, direct and needs no extra invocation or marshalling. However it can require some parameter massaging and requires a fairly good understanding of C datatypes and how they are treated by a compiler.
Rolf Kalbermatter  My Blog
Message 39 of 53
(990 Views)
I don't expect to hammer my computer with requests for environmental variables, so I don't really factor in the overhead.
I only factored in the simplicity of implementing the solution, not the cost.  All the info I needed was on one MS page.
Bill
CLD
(Mid-Level minion.)
Message 40 of 53
(936 Views)
