Can LabVIEW track the cursor, even when LabVIEW isn't the active application?
I'm using LabVIEW 8.2 on WinXP. I could use a Visual Studio .NET language if desperate.
(2,825 Views)
WindowXP send mouse move message only to the active application.
You can poll the cursor position from time to time using Input Device VIs.
Or you can use c/c++ hook technique to capture the mouse move message.
George Zou
George Zou
(2,820 Views)
Your cursor polling idea with the Input Device VIs works great here, thanks. I didn't have to figure out the c/c++ hook technique!
(2,808 Views)
