How to use the ActiveX class MLApp.DIMLApp - Matlab ActiveX interface
Hello:
I'm try to pass some data from LabVIEW to Matlab using the ActiveX class MLApp.DIMLApp.
Could you please provide me with instructions on how to use the Methods and properties of this class.
For example
What should be wired into the "workspace" parameter of the "GetVariable" Method
How to use the "PutFullMatrix"
Your help will be highly appreciated
Thank you.
Felix Beltran
Message 1 of 8
(6,396 Views)
hey felix,
i have the same problem...i have been reading online and it seems that the registry for the activex control is messed up.  I tried to fix it but it still does not work. have you found a work around yet?
thanks,
erique
Message 2 of 8
(6,344 Views)
Hi Erique:
I gave it up unfortunately I'm up to my neck busy with other things. I just did all the code in Matlab to read the compressed data files I need without using the LabVIEW application program that did before.
I would appreciate anyway if you could let me know about any progress on this issue.
Kind  Regrads.
Felix.
Message 3 of 8
(6,333 Views)
Hi Felix,
I actually got it to work with the help of Marc Lawrence (I met him through one of these postings as well). If you still want to give it a shot, let me know and i could send you a copy of my vi.
erique
Message 4 of 8
(6,316 Views)
Hi Erique:
I'd would be grateful if you could send me the Matlab - Labview interface .vi  .
Thank you.
Merry Chrismas & Happy  new Year.
Regards
Felix
Message 5 of 8
(6,310 Views)
Hi Felix,
In my setup, this vi works.  If you encounter any problems, please let me know.  Merry Christmas to you too!
Erique
Message 6 of 8
(6,301 Views)
Hi Erique:
Thanks for the vi. If it is not too much trouble could you please compiled for LabVIEW version 7.1 ? I still don't have version 8 and it soes run with my  Labview version 7.1
Once more thank you for your help.
Hasta La Vista Amigo !
Message 7 of 8
(6,290 Views)
Hey Felix,
Im sorry but I don't know how to do that.  I'm very new to labview and i still don't know how to compile it to version 7.1.  Maybe you can tell me how to do it, then I'll give it a shot.
Erique
Message 8 of 8
(6,276 Views)
