Can Multiple DMM instances access the same DMM instrument ?
My one main experience with TestStand involved putting together a class-based HAL when I was also pretty new to LVOOP.  So I was a bit of a noob at the time, plus my memory of it isn't clear and thorough.  With all that as caveat, I'll try to comment.
I too struggled with the need to instantiate an instrument, open its communication connection just once, and then be able to use that instrument object (and it's initialized comm reference) repeatedly.  I wound up making a little Action Engine lookup table for the instantiated objects with their comm references.  I called it my instrument registry.  I think I had to do another thing like launch a background LabVIEW process that first made an initialization call to the registry, and then just ran idly to prevent garbage collection on the comm references while I was executing sequences.
When retrieving a "live" instrument object from the registry, the terminal must have been of parent type already.  I don't recall needing to cast it before calling the dynamic dispatch HAL functions.
It's possible all the "registry" mucking about I did wasn't necessary but it was the solution I managed to find which preserved open comm connections.
-Kevin P
Message 11 of 11
(258 Views)
