02-21-2003 02:11 PM
02-21-2003
05:01 PM
- last edited on
05-29-2025
08:20 AM
by
Content Cleaner
The latest version of NI-DAQ can be found here. The first reference I can see to WinXP is for version 6.9.2 according to the list here.
07-19-2012 06:56 AM
Respected Sir,
I am now trying to interface LabVIEW with hardware via NI-DAQ
In my old labview 5.1 version, Ni-DAQ 6.5 was used.
I would kindly request you to please tel me which NI-DAQ version is used for labview 8.2 and also compatability to support hardware already used in 5.1 version.
Thnaking You
Yours faithfully
M. Vijay
07-19-2012
07:22 AM
- last edited on
05-29-2025
08:21 AM
by
Content Cleaner
Did you try a search? http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248
NI-DAQ was renamed to Traditional DAQ since it was replaced by DAQmx. New designs should use DAQmx unless you are using a card that is not supported by DAQmx. The Release Notes for the specific DAQmx version will tell you what devices it supports.
07-20-2012 09:00 AM
Respected Sir,
Thank you very much for your kind help.
I install NI-DAQ 6.9.3 in labview 8.2 and is also compatability with labview 5.1.
I open the old computer window 95 cpu to find any national instrument PCI card is present or not, but i not find any PCI card.
Actually the instrument run by (labview 5.1, windows 95, Fieldpoint 1000, FieldPoint Explorer 1.6, NI-DAQ 6.5.1) is worked by other persion is retired from the department.
It was worked perfectly and take measurement by them.
The probelm now i received is connection to auquisition board was not found when i run probe.vi file in labview.
If FieldPoint 1000 hardware is using he instrument means there is no need TO USE NI-DAQ PCI card?
I would kindly request you to help, i do not know what to do now.
Thanking You
Yours faithfully
M.Vijay
