Can Nigel be used during the free trial.
I am trying to evaluate it to see if i want to upgrade my installation, but in the free trial of the 2025 q3 software i just get an error when trying to use Nigel at all. Is this supposed to not be available during the evaluation period?
Message 1 of 10
(990 Views)
yes you can
CLA
Message 2 of 10
(928 Views)
Hi Tim,
In general, the Nigel AI Advisor is not available as part of the free trial of LabVIEW or TestStand. Nigel requires an active subscription or service program to use, which does not come with the LabVIEW evaluation.
If you have an active subscription or SSP for LabVIEW, you should be able to get access to Nigel even in eval mode. Make sure the serial number you have with service is connected to your ni.com User Account that you use to log into Nigel. You can confirm the steps here - https://www.ni.com/en/support/documentation/supplemental/25/access-nigel-ai-advisor.html
Hope this helps!
Austin H.
Product Manager
NI Test Software
Message 3 of 10
(847 Views)
@ahillinaustin wrote:
Hi Tim,
Hope this helps!
according to MS copilot, NI Nigel is included in
- LabVIEW Professional
- LabVIEW+ Suite
- TestStand Development System
you need an valid NI account, and you are prompted to login into that account, when starting NI Nigel
Message 4 of 10
(801 Views)
So I'm assuming that Community edition is also a no-go since its not in your list.
Message 5 of 10
(490 Views)
thanks for the reminder, I do have a valid labview community edition on a privat machine, but it is labview 2025 q1 32 bit
I am downloading q3   and plan to take a look over the weekend.
Message 6 of 10
(473 Views)
Nigel AI Advisor is not included with the LabVIEW Community Edition.
There is a known issue where Nigel is installed with LabVIEW 2025 Q3 Community Edition, but we're looking into fixing that in a future release. As Austin said in his earlier post, you can't use Nigel unless you login with an account associated with an active subscription or SSP for LabVIEW Professional Edition.
[Edit] I realized that Austin didn't specify Professional Edition, and my answer is incomplete. Here's the explanation from NI Nigel™ AI Advisor for Test & Measurement Workflows - NI: "To use Nigel in LabVIEW, you will need an active subscription to LabVIEW Professional or the LabVIEW+ Suite, or a valid NI software service agreement through a single-seat perpetual license, volume license agreement, enterprise agreement, or similar license types."
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 7 of 10
(467 Views)
Thanks for clarifying.  I thought that it was too good to be true, honestly.  Would have been a great learning tool for those of us wanting to learn new things with LabVIEW.  Maybe a way to subscribe to Nigel in the future.
Message 8 of 10
(459 Views)
so I explicitly de-installed every NI package via Packagemanger, De-installed Package Manager via Control Panel, restarted machine and then installed labview community 2025 q3
I rememeber, there was a generic serial for community edition, but this is no more the case for the recent Community Edition.
As I also have a valid Labview Professional perpetual licence, and a valid Labview Professional  subsctiption licence, both registered to my account.
so when installing labview community via offline installer, the NI installer asks me to install various other NI package, eg. NI Nigel.
but when looking into NI licence manager, the community edition is bound to an extra license (406 days remaining), while NI Nigel is bound to my Labview Professional  subscription license (204 days remaining).
Message 9 of 10
(355 Views)
That sounds correct, but please note that we're not planning to support using the NI Nigel AI Advisor with the LabVIEW Community Edition (via your LabVIEW Pro entitlement) in the future.
BTW, LabVIEW Community Edition never had a serial number activation. You might be thinking of the Beta.
Christina Rogers
Message 10 of 10
(338 Views)
