Can VISA run-time engine be added to deployment post build?
I forgot to include the VISA run-time engine when building my TS/LV deployment. Can the VISA run-time engine be added to a system after it is deployed?
jvh
(3,286 Views)
Accepted by topic author jvh75021
If you would just like the RTE on a certain computer, they can always download it from NI's website.
But if you mean you would somehow like to modify your installer, post-build, its not possible.
Cory K
(3,273 Views)
I assume I would need to find the installer and run it. My build would have used 4.6.1 if I had checked it. However I see that 4.6.1 is no longer available at the NI site and my deployments would probably be looking for 4.6.1.
Thanks for posting.
(3,267 Views)
In that case i dont think VISA is all too picky, a newer one should work, no?
Else you can make an installer with everything included and reinstall, or a mini one with just VISA as an addendum.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,262 Views)
Right you are, 4.6.2 worked fine.
Thanks!
(3,250 Views)
