FTP File tranfer problem
I am having problem in transfering the entire file from cRIO to my local PC.
Only partial data from file getting tranfered.
My file size in cRIO is 156MB
But only 15 MB of data is getting transfered to PC.
I have used file tranfer of NI MAX.
(4,536 Views)
Hi Dhrubajyoti,
did you try to open your cRIO drive with the explorer or another FTP Client? Did you get an error?
Mike
(4,526 Views)
I used NI-MAX application.
I have right clicked on cRIO device which is detected and there I got an option of file tranfer from cRIO to my local machine.
(4,518 Views)
Hi Dhrubajyoti,
which error did you get, if you get one?
Mike
(4,510 Views)
Hi Dhrubajyoti,
If you put  -------   ftp:\\ <<Your cRIOs IP address>>  --------     into your web browser all the contents of data saved onto your cRIO should appear.
From this you could right click and save the file you want onto your hard drive.
Hope this helped!
John McLaughlin
Academic Account Manager
National Instruments UK & Ireland
(4,499 Views)
I have heard stories about the FTP results not getting updated after a copy.
make sure you refresh.
Ben
(4,495 Views)
