Can XY Graph add a single point to a plot without redrawing previous points?
I guess if I clear the graphs once in a while that would fix the memory problem.
But what is the maximum amount of data I can save with running into issues?
because in my particular application I will have real time data coming in, and I will need to display them constantly.
Message 21 of 26
(1,512 Views)
Thanks for the tip! Smiley Happy
Im not sure...how do I check that?
Message 22 of 26
(1,511 Views)
I have checked the box to "clear data on each call"
Message 23 of 26
(1,510 Views)
Thanks! I think the problem is solved, it runs forever nowSmiley Happy
Just one more thing, my input array size  is 128x40 (so 40 timepoints).I want to plot this, and on the next iteration (another 128x40 array)  append this new data to the exisitng one, so it is continuos (so the x scale would go from 0-80 now, instead of 0-40)
How can I do this?
Message 24 of 26
(1,506 Views)
SinceI can't change the update mode on a graph, I used a chart instead,  so now the x scale is continuous.
But would it affect anything else?
Message 25 of 26
(1,503 Views)
How can I do this?
Since the points are spaced equally in time, you should use a simple charts instead of xy graphs.
If you want to stay with the xy graph (why???), you need to keep track of X. Instead of tapping into the iteration terminal, you need to keep the current x in shift registers across all your loops and increment whenever new data arraives.
Message 26 of 26
(1,501 Views)
