07-30-2007 09:20 AM
07-30-2007 09:51 AM - edited 07-30-2007 09:51 AM
Opena VI reference to the VI in question and look for the properties in the "metrics" section.
Of course the task manager does not report memory on a VI basis, just the entire LabVIEW process, so you most likely won't get the same numbers.
Message Edited by altenbach on 07-30-2007 07:53 AM
07-30-2007 09:57 AM
07-30-2007 10:08 AM
07-30-2007 10:22 AM - edited 07-30-2007 10:22 AM
Message Edited by altenbach on 07-30-2007 08:22 AM
07-30-2007 11:12 AM
08-30-2013 07:33 AM
--- For the record, this does not work. The help plainly states that "You cannot read this property if the VI is running".
That means that a VI cannot monitor itself (or it's children).
If you try, you get 0 and an error ("The VI is not in a state compatible with this operation").
