read label subvi
im trying to read the label of a subvi.
I created a subvi, lets call it example.vi. When i add this subvi it shows its label over the icon.
When i now double click this text, i can change it to, ... test1.
And this is what i need as a string variable, this labeltext.
Is it possible to "read" this text inside the subvi?
Thank for your help
kr
Luke
Message 1 of 13
(4,376 Views)
Thank for your help
kr
Luke
Have you tried using a property node?
Bill
CLD
(Mid-Level minion.)
Message 2 of 13
(4,372 Views)
Hey Bill,
yes i tried the propertynode but i can only find the option to read the vi name (example.vi) not the specific name i gave the subvi
after addig it to my program
br
Luke
Message 3 of 13
(4,368 Views)
@Lukestar wrote:
Hey Bill,
br
Luke
I'm sorry - I completely misread your first post.  Let me go back and take another look at this issue...
Bill
CLD
(Mid-Level minion.)
Message 4 of 13
(4,357 Views)
Hey Bill,
no problem 😄
there could be an alternative solution:
when i could add a textfield (string) to the subvi, which i can read inside the subvi.
i will test this now ...
br
Luke
Message 5 of 13
(4,348 Views)
I have to admit I've never thought about doing this before.  I thought you were refering to the label of an object inside the subVI, not the label of the subVI object on the main BD.  Hmmmm, it's not obvious to me.
Bill
CLD
(Mid-Level minion.)
Message 6 of 13
(4,347 Views)
The obvious alternative is to just pass the string into the subVI.  This would require adding another input the the subVI.
Message 7 of 13
(4,336 Views)
Is the subvi reentrant?
Message 8 of 13
(4,307 Views)
Hey,
sorry I am from Germany and I use a german version of LV.
I tried to translate "reentrant" with dict.leo but I could not find a translation whit that I could
give you the information.
can you describe what you mean.
br
Luke
Message 9 of 13
(4,293 Views)
Hallo Luke,
"reentrant" heißt in der deutschen Version "ablaufinvariant" (VI-Eigenschaften -> Ausführung).
(Falls es für dich einfacher ist: es gibt auch das deutschsprachige www.LabVIEWforum.de !)
Why do you need that label inside the subVI at all? When you need that label as a parameter inside the subVI you should make it a regular input to the subVI (as has been suggested before)!
Message 10 of 13
(4,284 Views)
