Can a fill slide be colored like a meter
Is there a way to make a slide fill in with multiple colors, kind of like how the background of a meter looks, so that different value ranges have different colorations.
(3,575 Views)
This may not be exactly what you are looking for, but there is a ramp
control in at least the classic controls palette. It has a color ramp
and a color box that displays a color based upon the value.
Greg McKaskle
(3,575 Views)
With a Little Imagination and tools like Control Editor, you Can do many custom controls.
I am Attaching two Control Slides, with Color Ramp like the meter.
What I did is I replaced the Background of the Meter with a Color Ramp Picture using the control Editor. I hope you are familiar with customizing controls. The Question is Where do I get the Color Ramp Picture. I used the 3D Surface Graph. Went inside the Properties of CW3DGraph Control and Selected Color Map Style. Once Inside the Color Map Editor I created the Ramp I wanted. Very easy to do this.
I then Copied the Window using Alt-PRNT SCRN to MSPaint. I then Cropped the Image so that I get only the Ramp and Nothing else, and Saved it.
See If this Satisfies your need. It was a Goo
d Challenge. If you are not clear How I did it, you can still use the controls as they are. Just Choose these Files using "Select Custom Control.." from the Function Palette on your Front Panel.
Mache
Good Luck!
Mache
(3,575 Views)
