Can a plot line width be larger than level 5
When I programming in Labview 6.1, in the property of plot, I found the line width only have 5 level. In my case, I need a much thicker plot line than level 5. Is there anyway to realize increasing the line width beyond the 5 options provided in Labview?
Really thank you if you can help me.
(3,898 Views)
You can programmatically thicken lines by creating a duplicate data plot that is offset from the original.  Then use the Plot.FillTo property node and fill between the original and the duplicate.
I back saved the example from LV7 to 6.1, but I have no way to test it on 6.1
2006 Ultimate LabVIEW G-eek.
(3,890 Views)
Thanks a l`````lot, Jonnie 5.
Even the VI engineer didn't give me a solution. Smiley Wink
I solved my problem following your thoughtway (also add a 'minus offset' to the actual signal so that the actual plot locates in the middle of the 'thick line'.) Now I am so excited to start my new experiment by using this program. But I can't fill the space between actual and my duplicate plots into solid color. I can only see three lines on the panel. Is there any tip to get a thick solid plot? Sorry for trouble.
weiwei8688
(3,863 Views)
You can also use the picture control to plot a graph. Look at the shipping example called Waveform and XY Plots. Buried in them is a subVI called Draw Multiple Lines. It has a pen width setting. You can make it as thick as you want.
(3,854 Views)
not sure why it's not filling if you have a positive non-zero offset.  Make sure you're setting the active plot number before the fillto property.
LV6.1 example attached w/ + and - centered around actual.
(3,850 Views)
excellent idea (as usual) Dennis!
the top level example is in examples\picture\demos.llb
the subvi is in vi.lib\picture\picture.llb
Message Edited by Jonnie 5 on 08-11-2006 10:29 AM
(3,847 Views)
