how to realize the function that three events happen continuously??
Sorry, I can't describe the question in english ,so  I speak Chinese
想实现这样一个功能:点击一个按钮后,有三个事件连续发生,但是第一个事件发生后2秒钟,第二个事件才自动的发生,然后再2秒钟后第三个事件发生,另外这三个事件都是给同一个指示量赋值,请教大家了?如何实现呢……
(2,716 Views)
I’m not sure if I understand your question. From what I understand you want to send a sequence of timed events with the action of 1 button.
For doing this you can enclose your 3 events in a sequence, with a timing function inside a case connected to the button or an event structure, here is an example.
If you are using more events I recommend using a state machine architecture instead of the flat sequence
I hope this helps
Message Edited by BeCeGa on 08-11-2006 09:37 AM
Benjamin C
Principal Systems Engineer // CLA // CLED
(2,666 Views)
