Can a point by point VI be used in a post anlysis? How?
Hi there,
I am working on the data post analysis. I tried to find the Savizky Golay filter. But I can only found the point by point VI, not array-based VI. So Can I use the point by point Vi in the array based post analysis instead of in the real time analysis? How? Any suggestions?
Thank you very much.
Warmest regards,
Chong
(2,714 Views)
Hi Linghu
You can download an implementation of the Savitzky Golay filter for nonuniformly spaced data from
www.sciware.com.au
The implementation has an example that is array based but also the option of doing point by point smoothing.
Regards
Message Edited by SciWare on 05-04-2005 10:13 AM
Kurt Friday
www.sciware.com.au
(2,703 Views)
Dear Mr. Friday,
Sincerely,
Chong
(2,672 Views)
