How do I save UI control value and recall them
I have a task to save the User Interface Control value (for example per user) and then on the next time the specific User can recall its control values he had put last time.
How do I perform a simple UI control Save and reload?
Yariv
(2,878 Views)
You can write some code yourself to do this (using the Get\Set Control Value methods or local variables), but the fastest way is probably to download OpenG's file toolkit, which includes VIs which save a FP to an INI file and then load it back.
___________________
Try to take over the world!
(2,874 Views)
I have OpenG, where is it located?
Yariv
(2,869 Views)
File I/O>>OpenG Variant Configuration File VIs>>Write Panel to INI.
___________________
(2,865 Views)
