Can a "object reference" type from TestStand be used for Labview VIs
I am creating a test sequence in Test Stand and I am looking to use a "object referrence" type stored in the globals of TestStand as an input to VIs that I will use later in TestStand.  The object can be from .NET or ActiveX.  I need to know if I can use a input that will support either type.
(2,570 Views)
Hi Mcfrenzy36,
Object references can be used for LabVIEW. I have found an article that teaches how TestStand handles Activex object references. Here is the linkt o it:
http://zone.ni.com/devzone/cda/tut/p/id/2984
I hope that this helps.
Perry S.
(2,544 Views)
