Bug? What's wrong with this?
can someone please take a look at this vi file.. why is the "if" block in the formula node executed incorrectly?
Thanks..
Message 1 of 8
(3,704 Views)
What is not working as expected? It seems you're assuming the variables in a Formula Node keep their value from a previous run. This is not the case. If you need to retain the variables from a previous run you need to use a shift register and feed the previous value into the Formula Node.
Message 2 of 8
(3,700 Views)
Accepted by topic author splee
Something like that:
Message 3 of 8
(3,694 Views)
exactly "diff = now + previous" does not execute as expected. So the value of "previous" is not retained?
Message 4 of 8
(3,689 Views)
Yes, it is initialized to 0 in each run. If you want to keep the value you need to use a shift register and feed the value to the formula node.
Message 5 of 8
(3,686 Views)
Dmitriev,
The "previous" with a downward-pointing arrow is an input or output?
Message 6 of 8
(3,685 Views)
@splee wrote:
Dmitriev,
It's a shift register, the arrows can be looked at as a "loop around". The downward arrow can also be an input (if something connects from the left) but the point is to send the "/\" back to "\/" the next loop.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 8
(3,667 Views)
@splee wrote:
Dmitriev,
Sounds to me like somebody needs to spend some time with the LabVIEW Help and tutorials....  To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. There are also several Technical Resources. You can also take the online courses for free.
Message 8 of 8
(3,648 Views)
