Can an input be used to determine output of a polymorphic VI?
Hi All,
I am communicating between a producer/consumer loop using a queue. The queue'd element is a cluster made up of a type-def enum and a variant. Data-type in the variant will depend on the state of the enum.
I would like to use a subVI to convert the variant back to the original data-type. The first option that occurs is a simple subVI with an output for each data-type and wire only the relevent output. The second option that occurs would be a polymorphic VI where the user selects the relevant state.
What I would like to do is wire the inside terminal of my case-structure to my SubVI and have it dynamically change (before run-time) to the appropriate output-type. This would be similar to the existing 'auto' function on polymorphic VIs. Can anyone tell me if this is possible?
Regards and thanks,
Delta
(3,995 Views)
Accepted by DeltaJ
Yes it's possible with LVOOP, the first thing I thought when looking at one of the first examples of LVOOP was 'Runtime Polymoprhism'.
What you do is create a class 'DataTypes' , with a method 'Read'
Then a class 'DataType1'  which inherits from 'DataTypes'.
You create a queue of type 'DataTypes', and you sent in an object of type 'DataType1', in your dequeu system you use the 'DataTypes.Read' method, LabVIEW will select the proper handler of a child class to deal with the data.
There should be an example (can't check right now) that shows that for 'bacteria'  testing or something like that.
Ton
My LabVIEW Ideas
(3,982 Views)
Hi Ton,
Looks like exactly what I need - many thanks. Its also going to be a good excuse to start working with OOPSmiley Wink
If you get a chance could you post a link to the example or maybe a copy of the code.....I've searched but I can't find the bacteria example you mention anywhere.
Delta
(3,951 Views)
I can't find it neither, but the LabVIEW examples have 'dynamic dispatch' example that shows the idea.
Ton
My LabVIEW Ideas
(3,940 Views)
Thanks Ton - it looks likes something I can definately use!
Regards and thanks,
Delta
(3,912 Views)
