Can communicate one direction in DDE app, but not the other
I am writing a Labview app and trying to use DDE to transfer data between it and another app. I can retrieve info from the server app to my app, but cannot send from my client to the server app. I have a conversation link, but the app returns the error "invalid ADVSTART" error. If I drill down into the DDE Advise Start vi, it shows the error is generated by a sub VI called DDE Master Control after which point I'm a little lost. Can anyone give me an idea of why this might be happening. The DDE service, topic and item numbers are the same another app (written in VB-no source) uses to communicate which has no problems.
(3,073 Views)
You cannot send data using the Advise Start VI. You should open a conversation link and use the poke VI.
Several DDE sequences are often used:
Read data:
Open ==> Request ==> Close
Continuous read:
Open ==> Advise Start ==> Advise Check ==> Advise Stop ==> Close
(Advise Check is often put in a loop)
Write:
Open ==> Poke ==> Close
In case you get a strange error, check the error cluster wiring. When an error has occured, none of the DDE VI's after the error will be executed.
(3,073 Views)
The previous post is absolutely correct in terms of the programming model for DDE.
In case you're interested, there is more information regarding DDE use in LabVIEW:
DZ Tutorial: Using DDE in LabVIEW (Windows Only)
Also, just as a FYI, DDE technology has been replaced by ActiveX and a recommendation might be to think about using ActiveX for future inter-application communication.
Best of luck.
(3,073 Views)
