Can i save VI front panel as a picture?
Hellow!
Is it possible to save the VI frontpanel as a picture? Thanks!
Message 1 of 12
(4,578 Views)
Hi happybird,
you can use the invoke node -> Get Panel Image and use one the graphics format vi's (located in the graphics and sounds palette) to save to disk.
hope this helps
Message 2 of 12
(4,567 Views)
This recent post show how to get the front panel and the diagram image. Just use half of it. 🙂
Message 3 of 12
(4,563 Views)
I see,but my version is labview 7.0,so there's no get panel image method.if i print the screen,it can not show all the panel image,because my front panel is quite big.
Message 4 of 12
(4,543 Views)
The Get Panel Image method IS available in 7.0. Drop the Invoke Node function on the diagram. Right click and do a Select Class>VI Server>VI. Right click again and select Methods. It's the 11th item down.
Message 5 of 12
(4,539 Views)
Here is a VI I created to do just what you want. It's not that elegant but it works.
Message 6 of 12
(4,531 Views)
I have ran this VI,but why it doesnt work,it appears"LABVIEW an input parameter is invalid" NI488 ,Command need GPIB controller to be controlled in charge"
Message 7 of 12
(4,512 Views)
What version of Labview are you using??
ssmith
Message 8 of 12
(4,506 Views)
Labview 7.0
Message 9 of 12
(4,503 Views)
Here's a tiny VI I posted a while ago but now in LabVIEW 7.0.
Just place it inside your VI in a event or case structure. Whenever it is called, it takes an image of the front panel of the calling VI (not of itself, of course :)).
Let me know if this works for you. 😄
Message Edited by altenbach on 06-09-2005 04:20 PM
Message 10 of 12
(4,492 Views)
