internal.llb build error
can someone give me advice on what might be causing an internal.llb error when I use the application builder? I've made sure the vi in question doesn't exist in two places. I've tried rebooting my computer. I've tried force compiles, mass compiles. The vi itself does not have a broken arrow and runs just fine. I'm out of ideas? Does anyone have any suggestions?
(2,778 Views)
Hello Jim77215,
What error message/code do you get when you try to build an application? Which version of LabVIEW are you using? Does your VI have subVIs and do you call them dynamically?
Here is a link to a knowledge base documents that might be useful, if you haven't followed the suggestions given there already:
Error 1003 Occurs When Trying to Create an Executable
Good luck and let me know if you still have problems building an application.
Shakhina P.
(2,761 Views)
