Can i select which plots show in graph?
Hey guys, I want to know
if I have a graph and I have like 8 plots
can I select which plot show like, in some cases I want to see only 2 plots, in other case I want to see 1 plot only, and other time I want to see all the plots, can I select or make something to make it happens?
Message 1 of 12
(4,158 Views)
Hi EduU,
you could either
-select the plots before building the array (or cluster) for the graph
or
-"hide" the plots by using transparent color for them (via property nodes)
Message 2 of 12
(4,154 Views)
Well, but I'm asking when I'm running the program
because I have a graph that show 8 plots, but sometimes I want to focus only in 1 plot... so with 8 different plots is difficult!
I want to hide the other 7 plots for a while so I can focus in only one plot.. after that I put the plots back, it's possible?
Message 3 of 12
(4,151 Views)
Hi EduU,
what I wrote in message 2 is possible in runtime too Smiley Wink
Message 4 of 12
(4,149 Views)
Accepted by EduU
Just follow the attached VI
change the condition acc. to show which ever plot you want to show
Message 5 of 12
(4,146 Views)
Yes, I tryed it here.. but after I put all Transparent... I have to select the color again... and that's not good x(
don't have an easier way? like only hide and after put it back?
Well maybe it work, shrekt I will try here in my program
thanks for the example!
In my case as I have 8 plots, I can change the T or F condition to a Case selector right?
So I hide 7 plots and show only the one I want to see!
Message Edited by EduU on 01-12-2010 06:10 AM
Message Edited by EduU on 01-12-2010 06:12 AM
Message 6 of 12
(4,145 Views)
Hello Gerd,
I found another way than coloring the plot transparent (btw. with better performance for huge data graphs). It has another advance since the graph remembers the original color.
greets, Dave
Message Edited by daveTW on 01-12-2010 01:12 PM
Greets, Dave
Message 7 of 12
(4,143 Views)
Hi Dave and shrekt,
yes, setting the plot invisible is surely better than transparent Smiley Wink
So EduU: until now you got 3 possible solutions for your question!
Message 8 of 12
(4,138 Views)
Only one question, where can i select invisible at the color of plot? =x
I didn't find it here!
Thanks for the help guys!
Message 9 of 12
(4,134 Views)
Message Edited by daveTW on 01-12-2010 01:21 PM
Greets, Dave
Message 10 of 12
(4,128 Views)
