Can labview produce a .exe that will run on PocketPC or WindowsCE?
Can labview applications be built into an executable program which will run on PocketPC or WindowsCE operating systems? If not, can source code be generated which can be compiled for these operating systems?
(2,711 Views)
Yeah but you will need the LabVIEW PDA Module add on.
Using this module you can build applications for Palm OS, Windows Mobile for Pocket PC, and select Windows CE OS devices.
(2,708 Views)
You should be aware that the PDA module does not support many features which are available in the desktop version of LV. Try reading the documentation available on this site. If you want this, I suggest you wait for version 8, which appears to be much better in some areas.
___________________
Try to take over the world!
(2,696 Views)
