Can not find device in Labview with arcnet PCI20U
I have installed the driver for ARCNet PCI20U-CXS from Contemporary Controls Inc.
But My Labview can not find the device. Any suggestions?
My system is Winxp+Sp2, Labview 8.2
(2,575 Views)
Hi Philip,
I looked up the device you mentioned, and it looks like it is a PCI device. Is this correct? What driver are you referring to when you say "[You] have installed the driver"? I am not really sure how this device would show up in LabVIEW; I searched the manufacturer's website to see if they have any LabVIEW VIs that perhaps call into a DLL to interface with the board, but I found nothing. They did have some C code available though.
I would suggest contacting the manufacturer to see if they provide any VIs to interface with the board using LabVIEW.  Hope this helps. Thanks.
Ebele O.
(2,566 Views)
