Can not go on to setup internet toolkit 6.0.2 to the labviwe 2009
When install this module, it always popup a warning that it need the labview 8.6 installed. Can give a solution to resolve the problem? thanks.
David
(2,601 Views)
According to
LabVIEW Module and Toolkit Compatibility Information it should work fine with 8.6
(2,595 Views)
LV2009 有 2009版的internet toolkit与之匹配
6.0.2版本可以与8.6匹配,所以,你可以考虑使用新版本的工具包,或者将LV版本降低
(2,576 Views)
