How can I programatically determine if running from a vi or from an exe?♦
Years ago, I thought I could use the Call Chain to determine this.  Perhaps my memory is wrong....
I need to determine whether running from a .vi or from an .exe so I can determine what the file version of the .exe is, if it's running from an .exe.
Tom
(3,424 Views)
Use an application property and select property "app.kind". Here are the possible results:
  1. Development System, including the Base Package, Full Development System, or Professional Development System
  2. Run-Time System
  3. Student Edition
  4. Embedded LabVIEW, including LabVIEW Real-Time
  5. Evaluation
  6. Custom
(3,423 Views)
You're a fast typist!  Thanks!
-Tom
(3,418 Views)
Well, I copied the table from the labVIEW help. (Almost) no typing required. 😄
(3,413 Views)
How can you do this on a RT target? It returns Embedded whether or not the application is compiled.
(3,098 Views)
Try this.
p.s. this works in windows. on an embeded device you may want to reverse the logic and see if the file is .vi ? Not sure if you get a .exe file on the embeded device since it's probably running linux on it.
Message Edited by pRoFiT on 01-06-2010 08:12 PM
- A minute saved is a Minute earned!
(3,070 Views)
