Can not load cin without Visual Studio installed
Hi
I have av lsb file that i can load into the cin and run without anyproblems on my computer that have MS VS2005 installed . But when i installed the program on another computer it says "cin not loaded". I have use the "Creating a CIN project in Visual Studio .NET 2005 using C++ for LabVIEW 8.0" that i found on the forum.
Any ideas?
/daniel
(2,949 Views)
@Greger wrote:
Hi
Any ideas?
/daniel
Your CIN has been compiled to link with dynamic link library versions of the Visual C runtime libraries. These libraries are not standard installed on Windows versions not at least one to two years newer than what the used Visual C environment is. So for Visual Studio .Net 2005 you probably need a Vista installation or maybe installing .Net 2.0 under XP might be enough.
You have a number of possible solutions:
1) Link the CIN with the static runtime libraries from Visual C.
2) Use an older Visual C environment that only uses msvcrp60.dll or earlier
3) Get rid of all runtime function calls in your CIN. For the most common C runtime functions, LabVIEW provides similar exported functions descriped in the External Code  Reference Manual.
4) Find the redistributable C runtime installer package for your C compiler and ship that together with your application and tell users to install that before running your application.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,920 Views)
