09-15-2009 12:21 PM
I am reading a text file (header.txt) which is put at the same directory as the vi. I use winXP & Labview 8.6. The VI reported error:
Error 7 occurred at open/create/replace file in OpenTextFile.vi.
However, I copied the file path at the end of the error message and pasted it in the IE address bar, and I found that IE can open the file.
Why it does not work?
Ryan
Solved! Go to Solution.
09-15-2009 12:23 PM
09-15-2009 01:56 PM
