Can someone convert this LV 8 vi to LV 7?
Hello, one of the forum members is trying to help me out and did some work on my vi, but I only have Labview 7.0 and he has Labview 8 which is not setup to save as LV 7. He provided this attached vi and suggested maybe someone in the forum may be setup to save it to LV 7, can anyone help? Thanks...
Message 1 of 29
(5,810 Views)
Thanks for posting to the NI Discussion Forums!  I have saved your VI in 7.0 for you.  I should let you know though that there were some subVIs that weren't found.  They look like third party driver VIs (PPS_UPC Initialize, PPS_UPC Close).
Kristen H.
Message 2 of 29
(5,766 Views)
Could you convert my LV8 llb to LV7 too?
We only have LV7 right now and the program is written by someone else who used LV8. So I want to convert this program to LV7 so that I can change the computer.
The llb file that I attached is using the library that the 3rd party company (Newport) provides. So I also enclosed the library setup program too.
Thank you in advance for your help.
Chan
Message 3 of 29
(5,692 Views)
Hi Chan,
The earliest version I have on my computer is 7.1, so I saved your VIs back to 7.0 but was not able to test whether it would open in 7.0.  I don't think there should be a problem with it, though.  Also,  there were a few subVIs that threw warning messages, just so you know.  Good Luck!
Kristen H.
Message 4 of 29
(5,674 Views)
I also have the same problem, i am using Labview 7.1 and after hard search in this forum and everywhere , i got those VIs that i could not open 😞 it would be great if you can help me open them with my Labview.
Thank you for any assistance.
Fadi
Message 5 of 29
(5,399 Views)
Hi Fad,
I could only get it back to 7.1.  I hope that works.  Also, just to warn you, I did see some build errors with the last one.
Kristen H.
Message 6 of 29
(5,373 Views)
Hi Kristen
Could you please convert these LV8.5 .vi's to LV7 too??
Smiley Wink
Message 7 of 29
(5,320 Views)
Kirsten,
Thank you so much! i really appreciate this 🙂
Best,
Fadi
Fadi
Message 8 of 29
(5,318 Views)
Hi, same problem.. vi made in 8, would like to have a look at it in 7. Could you please help me out?
Merijn
Message 9 of 29
(5,300 Views)
I made vi in LabView 2009 because I have Vista on my notebook, but in lab we have older computers with installed LabView7Robot Sad I saved my vi for LabView8 version. Please, can anybody save attached vi for LabView7? Thank you.
Message 10 of 29
(5,132 Views)
