Can someone create a program for me to calclate resistane using current and voltage. I need a visual graph and a few knobs for aesthetic purposes. PLS HELP
This is an excellent design, but there is a subtle issue. If the current or voltage is changed too rapidly, this will cause the queue to have a significant back-pressure of data elements, which could overload the Queue Read or Queue Write subroutines. Normally this won't be a problem, but for good coding practice you should include code to handle this. The best way would be to include a Queue Flush after data is sent to the queue. This is a rather advanced programming practice, so you may not want to delve into it. However, I'm sure that if you mention it to your teacher, you will get bonus points.
Message 11 of 21
(5,271 Views)
@bigmushy wrote:
THANKS SO MUCH
My reply isn't worthy of thanks  It is intentionally obfuscated; the only thing I considered implementing, but didn't, was encoding a snarky remark about Java in a boolean constant on the Block Diagram.  I hope you're good enough at Java to see the blatant silliness in my code.
But, thanks for giving me credit for a solution!
Jim
Message 13 of 21
(5,203 Views)
Thanks, Jim.  It has been a while since I saw a good RG to torture lazy students.
Message 14 of 21
(5,173 Views)
I've seen soo much worse i consider that ok ... 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 16 of 21
(5,124 Views)
@bigmushy wrote:
THANKS BRO, UR THE BEST!!!
I think the troll (me) has been trolled.
Jim
Message 19 of 21
(4,996 Views)
Or the troll is in too far and won't back down now.
Cheers
Message 20 of 21
(4,991 Views)
