Can someone help me with a simple alarm clock
Hi Everyone, Apologies if this is the wrong section or if ive missed anything simple but im new to labview at the moment.  I would like to create a simple user-programmable clock which shows a visible alarm (boolean LED) when the set time matches the current time.  I can currently get the current time to display on a time stamp and know how to change a time stamp into a control so that I can enter a time and date into the time stamp.  What I would like to do if possible is to make a system where by the boolean light will illuminate when a user inputtable time and date matches the current date and time.  Is there also any way to allow the LED to remain illuminated until a reset button is pressed?  Thanks in advance
Message 1 of 18
(6,694 Views)
See if this works ... (LV 2012 as you did not specify)
Message 2 of 18
(6,685 Views)
Hi, Thanks for that, where you have the alarm timestamp and 'get current date/time' going into the comparator with boolean output, I had set the comparator as = rather than > and I couldnt work out why it wouldnt function. Thanks
Message 3 of 18
(6,680 Views)
Probably because if you actually ever hit the EXACT time, you probably should've played lotto rather than spend all your luck matching a timestamp.  😉  I guess >= is technically more correct.
Bill
CLD
(Mid-Level minion.)
Message 4 of 18
(6,669 Views)
Hi, I am keen to explore into the alarm clock application. I am wondering if you have the lower version? I am using LV2011. Thank you very much 🙂
Message 5 of 18
(6,584 Views)
Hello ck76.
I saw your request and saved it for a previous version (LV 2011) as you asked.
See the attachment below.
Hope this helps!
Mondoni
Message 6 of 18
(6,566 Views)
Hi, thank you very much. It works great!
Message 7 of 18
(6,537 Views)
Message 8 of 18
(6,536 Views)
Smiley Happy
Next time you need any conversion, visit this board (Official Version Conversion Board).
Mondoni
Message 9 of 18
(6,514 Views)
great! noted on the link.
by the way, can I ask you another question? if i am running a VI, then at the click of a button, i wish to call another VI (sub VI) - just like doing a function call within a main program, and I wish to make this sub VI running in the foreground, how can I do so? so far, I am able to call the sub VI, but the sub VI is at the background. in other words, I have to switch window in order to see the sub VI.
Message 10 of 18
(6,490 Views)
