Can someone help me with the following VI's
1) One that can give me flicker generator signals(higher magnitude and lower magnitude high frequency noise)
2) One that can square the two signals above.
3) One that can filter these signals(50Hz)
4) One that can integrate these filtered signals.
5) Laslty, how can I display these integrated signals in PST and text format.
I thank you
Regards
mome
Message 1 of 9
(3,691 Views)
I'm curious...
Is this part of a class / course?
We can help you through this, but need a starting point.
JLV
Message 2 of 9
(3,664 Views)
How familiar are you with LabVIEW?
Have you tried? How far did you get? At what point did you get stuck?
Is this a simulation or actually involves real DAQ?
Is this homework for a course? 😉
Message 3 of 9
(3,663 Views)
Well, using student edition, see other thread
http://forums.ni.com/ni/board/message?board.id=170&message.id=197066#M197066
Message 4 of 9
(3,653 Views)
Is this part of this? from other threads...??
QUOTE:
Thank you gentlemen, in response to the questions asked.
  • The meter measures flicker in light
  • I will be getting a signal from the Flicker Generator and interface it with the DAQ card through to Labview program
  • I will then have to compare a Flickermeter signal that goes through a CPU with the one displayed on Labview
I do have a hard copy of the circuit diagram for a Flickermeter but unable to use this info to achieve my goal.
Best Regards
MLK
Message 5 of 9
(3,646 Views)
Here is yet another thread...
http://forums.ni.com/ni/board/message?board.id=170&message.id=197584&a#M197584
It is customary to give higher star ratings to those trying to help, such as Kenny.
It's probably a good idea to step through the solution, that way you get to learn what's going on...  which is why you're taking the course, right?
Message 6 of 9
(3,640 Views)
JLV-
How's the coffee this AM?
-AK2DM
Message 7 of 9
(3,635 Views)
2 espressos,
5 cups of regular..
need more...
MORE....
M-O-R-E!!!!
coffee..
Why did you ask?  Was it noticeable???
😄 😄 😄 😄 😄  LOL 😄 😄 😄 😄 😄
Message 8 of 9
(3,630 Views)
 JLV-
                      very-happy smiley    YEP   wink smiley
Have a nice day, eh!
Message 9 of 9
(3,623 Views)
