Can't Read Data from 6B13
While attempting to read the output of Analog Devices 6B13 purchased for NI I get the following error message. "AD6B Input Module - Read Data;6B Series Serial Port Receive Message:
Instrument not responding - Invalid parameter or invalid operation."
One the same backplane I have a 6B11 module that I have problem reading the
data. When using the AD test and configuration software both modules work as expected.
The NI vi is "AD6B Input Module - Read Data", which is used to read both the
6B13 and 6B11 modules.
(3,215 Views)
Hey Byron,
We've been working on this issue through email, so please let me know what the results are of highlighting the execution of your code. Thanks!
Justin E
National Instruments R&D
(3,191 Views)
The error is coming when attempting to read the response from device 0.
Device 0 is a 6B13. Device 1 seems to work ok, it's a 6B11.
After playing with things manually using Visa Serial vis I was able to
get it to read. The problem could be in 6B Map vi.
Also of note once I got it read with Visa Serial vis the Visa Serial Read vi indicates an error with an error code -1073807339 no error message. Visa Serial Read does return the 6B13 data.
(3,183 Views)
