Can't Run Bluetooth Examples (Error 1)
I am trying to set up Labview to control an Arduino via Bluetooth. I'm just starting out by attempting to connect my smartphone using the Advanced  Bluetooth Server/Advanced Bluetooth Client example vis. I plugged in my Bluetooth dongle and the dongle appears to be working using Windows drivers.  However, when I run Advanced Bluetooth Server, I get the following error:
Error 1 occurred at Bluetooth Create Listener in Advanced Bluetooth Server.vi
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488: Command requires GPIB Controller to be Controller-In-Charge.
I literally opened the VI and pressed run, so I have no idea what I could've done to change an input parameter.  Any suggestions on what the issue could be?
(2,829 Views)
can you attach a screen shot so that we can look at the input parameters. Both the server and client. Thanks
Applications/Systems/Test
National Instruments | AWR Group
(2,794 Views)
