Can't automate "Choose File to Upload" pop-up window in Internet Explorer
I'm trying to create a short VI that will upload a configuration file to a website.  I'm able to open the connection and use an invoke node to click the browse button (using the button's handle) but I can't seem to input a file path in the "Choose file to Upload" window, then click the "OK" button to load the file.  Any suggestions?
(3,093 Views)
Hey, I don't have any answer for you right now but I saw your post and wanted to let you know I'm looking into your issue with Kaleb.
John M.
(3,035 Views)
Thanks John!  I learned alot from the connectivity course this week.  I'm going to make an attempt using the POST method.  I'll post my new VI once I test it on the actual hardware.
(3,010 Views)
