Write Elvis Programms on Labview
first i am new on Labview.
I wanted to write a Program on Labview for NI Elvis II.
But i didnt find anyy possibility using and input from the Elvis Board.
Do i need to install some special Libs? If yes where are they?
Greetings
Nikolai
Message 1 of 15
(5,665 Views)
EDIT: I may have misinterpreted your post.
The program runs on your computer and the Elvis is just a device your program communicates with.
After installing the Elvis software examples can be found in the Example Finder, and demo applications can be found in your start menu.
Message 2 of 15
(5,658 Views)
i have installed Elvis Software and seen the Apps like the Ossi or the Function Generator.
But i will write my own programms with Labview (which is possible).
I would know how i can access Elvis on labview.
So i can say U from port x should be readed
Message 3 of 15
(5,651 Views)
Launch LabVIEW, then run Help >> Example Finder and search for Elvis.  Many examples should be installed.  Also go to your palette on the block diagram and search for Elvis and you'll find the palette with all the function calls.
If you are new to LabVIEW you may want some free training.
3 Hour Introduction http://www.ni.com/white-paper/5243/en/
6 Hour Introduction http://www.ni.com/white-paper/5241/en/
LabVEW Basics https://learn.ni.com/learn/article/labview-tutorial
Self Paced training for students http://www.ni.com/academic/students/learn/
Self Paced training beginner to advanced, SSP Required http://sine.ni.com/myni/self-paced-training/app/main.xhtml
LabVIEW Wiki on Training http://labviewwiki.org/LabVIEW_tutorial#External_Links
Message 4 of 15
(5,649 Views)
Thanks very much, i will try it Monday. (When can work with Lavview and Elvis)
Message 5 of 15
(5,644 Views)
Thanks for the Help but on the "Find Examples" there werent any Elvis Examples and what i needed was the Elvis on Block Diagram. But i searched there too and there arent any elvis blocks
Message 6 of 15
(5,588 Views)
This makes me believe the software isn't installed.  Did you install LabVIEW after the Elvis software?  LabVIEW must be installed before additional toolkits and drivers (like DAQmx).  If this is the case you can perform a repair install of any software and it should install it for all installed versions of LabVIEW.
Message 7 of 15
(5,547 Views)
i will reinstall the software, because i dont know which software was installed first.
Should i install
http://www.ni.com/download/ni-elvismx-14.0/4801/en/
or
http://www.ni.com/download/ni-elvis-software-3.0.7/3647/en/
i think the last one or?
Message 8 of 15
(5,521 Views)
Version 14 is the latest. You have not specified which version of LabVIEW that you are using. On the links you posted, look at what versions are and aren't supported and get the latest.
Message 9 of 15
(5,504 Views)
first i worked with labview 2013 but now i get a new computer with labview 2012. I could maybe install 2013 but i dont think itns necessary because the old versions are supported too.
arent the 2 programs not little different?
it looks for me like 2 diffrent types of software.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/de/pg/1/sn/ssnav:drv/q/elvis/
Message 10 of 15
(5,498 Views)
