Can't find Certain Function Blocks
I wrote code for a 4-bit Voltage supplier for a circuit last year and now I'm trying to recreate it and I cannot find these two blocks. Can someone help me know where I can find them?
(1,437 Views)
This looks like something scripted by DAQ Assistant, I presume that you configured a DAQ Assistant express VI and then invoked the right-click method to convert it into DAQmx code.
Santhosh
Soliton Technologies
(1,428 Views)
These vis were created using DAC Assistant. A task was created and then converted to DAQmx code.
The one on the left configures the task. The one on the right creates the output value(s).
Founding (and only) member of AUITA - the Anti UI Thread Association.
(1,422 Views)
