Can't find Daq assistance palette
Hi, everyone! Can't find Daq assistant palette. It wasn't revealed after the installation. Possibly, there's an additional module or toolkit for working with.. Thank you for answers!
(3,226 Views)
Accepted by Petr_Stepanov
Installation of what? If all you did was install LabVIEW, then you need to install DAQmx.
(3,211 Views)
Yes, Thanks!!!
P.S. I just installed evaluation mode of LabVIEW. Hope your solution'll help fix it.
(3,205 Views)
@Krolick wrote:
Yes, Thanks!!!
it will...
Drivers(comma),(pause for effect) add a Hardware Distraction Layer (whoops, I meant Hardware Abstraction Layer):smileyvery-happy:,  NI is pretty good at providing HALs but you DO need to know that there is no progamming language that delivers HALs with the development enviorment-  you get the HAL with the H(ardware).
Unlike other languages- the "LabVIEW's company" also sells (fairly good) hardware.  once you get that internalized you'll do fine!
(3,184 Views)
Did you mean that there's strong interconnetction between NI sofware and NI hardware? And it's better to deal with real chips?
If so, I comprehend it but need to simulate real device for my study.
Thanks!!!
(3,167 Views)
